Sputters out
Old May 27, 2015 | 12:02 AM
Jaidon_O's Avatar
Default Sputters out
When I turn the key car turns on and then sputters out. The second or third time it always comes on fine, or if I hold the gas down and rev for a few seconds. How can I fix this? Also after I get it going it sounds like it wants to give out and shut off. Car drives fine, this is the only weird issue I have.
Old May 27, 2015 | 09:15 AM
Check the sensors on the TB, possibly even clean the TB blade off.
A lot of times the IAC (idle-air control valve) is caked with carbon and preventing the car to idle properly.
Old Jun 1, 2015 | 01:14 PM
Jaidon_O's Avatar
I don't know much so I will have some dumb questions.. I cleaned of the IAC and that didn't do it, I am gonna clean the MAF sensor to, just gotta get me a torx screwdriver. I need alittle more explanation on what the TB sensor is or the blade. Thanks a lot
Old Jun 1, 2015 | 02:14 PM
The blade is the part that opens to let air in when you push the throttle down. Sometimes it gets stuck from the carbon build up.
There's a clean vs dirty look
Nas Escobar
Jun 23, 2014 12:33 AM
billyjblunt79
May 3, 2013 12:59 PM
Slugger088
Jun 17, 2011 03:57 PM
Gthirteen
Apr 8, 2011 08:23 PM
jeffsmonte
Sep 25, 2007 08:34 AM
