Speaker static
Old Jul 13, 2017 | 11:39 AM
RidesSubs's Avatar
Default Speaker static
2001 Monte Carlo LS
Driver's door speaker has static even with ignition off. Where should I begin?
My first thought was to remove the door panel and check for corrosion and ground issues. Anyone already had and fixed this problem?
Old Jul 13, 2017 | 11:59 AM
Jason B's Avatar
Have you wired anything new into the car or has anything changed electrically? I know sometimes if you add something with a lot of draw to the same circuit you'll get a lot of static. For example, on some older cars if you add something to the cigarette outlet that drew a lot of current you would get static through the speakers. I haven't looked through the wiring diagram to be able to say if that for sure would be the culprit, but i would say start with what may have changed, before taking things apart.
