6th Gen ('00-'05): Snap, crackle, pop. help please
Old Jul 4, 2017 | 06:23 PM
Bleedintoone's Avatar
Default Snap, crackle, pop. help please
Things I've replaced on my car:
struts
swaybar and swaybar links
Both control arms
Inner and outer tierods
Here are my symptoms:
​​​​​​when turning the wheel either way with the brake applied I get a popping sound in the front
​​​when accelerating from a stop sign or light, I hear a pop,pop,pop in the front end.
When reversing and turning the wheel all the way to the left I hear these rubbing sound that is continuous until I stop.
Also while driving slow in parking lots or my driveway I hear this high pitched squeak sound.
All of these seem to be coming from the drivers side and I'm lost, it's sounds awful
Old Jul 4, 2017 | 06:29 PM
Default Also
It's all stock 2005 Monte Carlo SS 138,000 miles
Old Jul 5, 2017 | 08:31 AM
Wheel hubs are pretty common on these cars, and most likely the issue.
Old Jul 5, 2017 | 05:33 PM
The wheel hub bearings were replaced 2 years ago. This noise is most prominent when I'm sitting at idle in park with the brake applied and turning the wheel left to right or vice versa there is a single pop that could be heard I've tried everything
Old Jul 5, 2017 | 08:14 PM
SuperchargedMonte's Avatar
It could be the front drive axle. Check the boot for any tears/rips. If any debris or dirt gets in there it can damage the joint.
Old Jul 11, 2017 | 09:06 PM
It ended up being the right rear wheel hub bearing it helps to have a helper to identify the noise
