Small block timing.
Old Jul 13, 2010 | 03:08 PM
TheMonteCarloKid's Avatar
Default Small block timing.
timing is being a real b***h with me. i have a 72 small block 355 in my 4th gen monte. and i had her set at TDC on #1 and set the distributor to fire on #1. and she worked great. problem was i didnt tighten the distributor clamp down and it bounced out and screwed the timing again. now i re-set the whole thing at TDC again and it wont fire. if anyone could send me a link or something on a detailed instruction on timing my engine i'd be quite happy.
Last edited by ChibiBlackSheep; Jul 13, 2010 at 03:16 PM. Reason: Watch the language please :)
Old Jul 13, 2010 | 03:54 PM
The Popcorn King's Avatar
Is it backfiring out the carb? It could be 180* out. Set piston #1 at TDC and take off the Dist. Spin it 180* and reset it. Try that.
Old Jul 18, 2010 | 07:33 PM
can i get some elaboration on that? i've heard two people say that could be the problem. but i dont fully understand how that would help. are you saying i should take off the cap and spin the rotor 180? if i did that wouldnt it be firing on 7 when it should be on 1? i've also heard i should set it at 8 degrees before TDC. and i've heard i should get it to fire on TDC and then dial in an 8 degree advance after i've got it running. IDK i've never timed an engine before and my dads not around to help anymore
Old Jul 20, 2010 | 09:34 PM
Justin Knight's Avatar
pull the whole distributor out. make sure #1 is TDC on compression not exhaust. set the rotor up and set your timing with a light at 8*. when you put the distributor shaft back in make sure the rotor is right at #1 on the cap.
Old Jul 20, 2010 | 10:51 PM
are you saying to set timing with a timing light at 8* after i get it running?
or am i trying to put it at 8 degrees BTDC and then set the rotor right on #1?
bbyblue74
Jul 16, 2023 12:16 PM
Dam20735
May 23, 2013 04:09 PM
wht02monte
Apr 26, 2010 08:28 PM
johnmxh
Oct 5, 2009 05:07 PM
BeachBumMike
Apr 7, 2008 08:39 AM
