3rd Gen ('78-'80): Signal lever broken
Old Nov 16, 2017 | 10:17 AM
Morgenroete's Avatar
Default Signal lever broken
Hi MCF members,
I have a 3rd gen 1979 Monte Carlo with a tilting steering column. The signal lever has broken off and I am unsure how to fix it. I've lost the ability to signal left and right turns. As well as the ability to activate and flash my brights (high beams). My local wrecking yard is not helpful and I am at a loss of how to fix/replace this. Please help!
Regards
Morgen
Old Nov 17, 2017 | 07:20 PM
vincenti's Avatar
To fix it you gotta tear into the column kinda deep & tilt columns are a hassle. If you have the funds I recommend just getting a replacement column from a salvage yard. Shouldn’t run you more than $75. I know all ‘82-88 g bodies are interchangeable, I don’t know about the ‘78-81s. A salvage yard would know, or look it up in the Hollister Interchange books.
Old Nov 18, 2017 | 04:42 PM
So I'm based in Toronto, my local (and only) you pull it yourself wrecking yard 'standard auto' literally burned to the ground last march. Creating a big parts shortage in the area.
I have gotten the steering wheel off and been able to look at the guts of my wheel. it seems the the lever was just attached to a piece of plastic that went up and down. Unlike later models there is no electrical wires going through to lever itself.
If anyone could tell me what the part was called or where I could buy a reproduction I'm pretty confident I could install it myself. I don't want to spend $300 bucks to buy a new one just for a lever. My column would look like this.
http://thumbs1.ebaystatic.com/d/l225...O-1PAfzbSg.jpg
Old Nov 20, 2017 | 09:02 AM
Jeffs02rwdSS's Avatar
If it was a hollow plastic tube, they were just pushed in place. Too remove you put the flat end of a standard screwdriver in the hole and twist remaining piece should come out.From that point you can just buy a new lever from parts store or make one yourself
Old Nov 29, 2017 | 10:31 PM
jakefluker's Avatar
I would check Opgi or Dixie Monte Carlo Parts but are very good, have used both and never had prob with getting parts .
