SERVICE TRAC SYSTEM ???
Old Jul 21, 2006 | 12:08 AM
fever42's Avatar
Default SERVICE TRAC SYSTEM ???
NEW DASH WARNING WHAT DOES IT MEAN AND HOW DO YOU SERVICE
2001 SS
[IMG]local://upfiles/99/7897B448D784480CB684FA4839C98834.jpg[/IMG]
Old Jul 21, 2006 | 09:43 AM
montejass's Avatar
Default RE: SERVICE TRAC SYSTEM ???
Have you pulled any codes from the system?
Could be an ABS sensor...
Old Jul 21, 2006 | 05:23 PM
Bigg J's Avatar
I have seen this in mine too (05 LT). I haven't done anything to investigate it, but I haven't seen it come up for a while either.
When it did come up, I shut off the ignition and started it up again and the warning disappeared.
Has anyone w/ Onstar signed up for the e-mail notifications? I thought it was pretty cool. Couple of weeks ago, I got the e-mail stating what diagnostics were run and it told me that my oil life was at 20%. Now, few weeks later, my "change engine oil" warning just came on, and before the sticker on the window expired at that. Pretty accurate setup.
Old Jul 21, 2006 | 08:28 PM
NYCRISS's Avatar
Could be a bad EBTCM or EBCM. Do you have a tire monitor light on? Is the ABS functioning properly?
Old Jul 21, 2006 | 08:58 PM
fever42's Avatar
FOUND PROBLEM, HAD INSTALLED 06 TAIL LIGHTS AND THE WIRING HARNESS WOULD NOT WORK WITH MY 01 CAR JUST CHANGED HARNESS OUT ALL'S WORKS
BY THE WAY 06 LIGHTS LOOK GOOD ARE AT LEAST I THINK SO. WILL POST PHOTO LATER
[IMG]local://upfiles/99/B28B475B3DF34E4B882DCB1970D38F86.jpg[/IMG]
Old Jul 21, 2006 | 09:25 PM
montejass's Avatar
06 will fit on our older models? Cool, what did you have to do to the harness?
Old Jul 22, 2006 | 02:50 AM
fever42's Avatar
JUST USE HARNESS FROM OLD LIGHTS, 2000/2005
FIT IS AS GOOD AS THE 00/05 MODELS.
teamfbody
34
Aug 11, 2013 08:22 PM
ladagosta
Aug 24, 2012 09:54 AM
Jokers1995
Jul 31, 2012 09:11 AM
milrlyt
Feb 4, 2012 07:14 AM
