Seafoam
RE: Seafoam
here's the thread we had a while back about it
https://montecarloforum.com/m_37478/tm.htm
here's the can, well its an older design, they have a new label out now
but it works awesome!
RE: Seafoam
so basic instructions
buy can
open can
turn car on
open hood
locate brake booster @ back of engine
pull off vacuum line with plastic knuckle thing
stick hose in (with plastic piece) into can andsuck out 1/3 to 1/2 of can, this may take a while, car may sound like its going to stall
shut car off, when 1/3 of can in, or try to stall it out, pour another 1/3 in gas tank, and another 1/3 in your oil (this cleans out all the seals and lifters and things)
then let sit for aboug 10-15 min, then start up and rev right up as hard as you can, blow out all smoke then take it for a drive, drive her like you stole it
buy can
open can
turn car on
open hood
RE: Seafoam
no, its just by feel, you can look inside as your pouring, there's nothing in that can that will hurt anything even if you put the whole can in...not gonna hurt anything...
so yah...just 1/3 right where you pour the oil in
1/3 in vacuum line
1/3 in gas tank
1/3 in oil
1/3 in vacuum line
1/3 in gas tank
1/3 in oil
RE: Seafoam
Here are some pics. Are what you talking about with the vaccuum line on the brake booster the yellow cap pictured here?
http://img519.imageshack.us/img519/7062/58542062qu6.jpg
http://img512.imageshack.us/img512/1206/77373448mb8.jpg
Thanks
Thanks
RE: Seafoam
yah thats where you pull the hose off, pull that whole yellow cap off and everything,
chris on yours its a big black metal round thing on the firewall on the driverside, should have a rubber line going into it, while the car is running pull that rubber line and connecter out of the booster and stick it in the can and let it suck about 1/3 of stuff out of the can, then shut the car off, and let sit for 10-15 min, when you start it back up rev it right up really good till it stops blowing the majority of smoke, then take it for a drive and drive it like you stole it
RE: Seafoam
haha doi lmao so tell me josh on my car what color is thingamabobberthingamajigwhatchamacallit?
now the problem is finding how to make this work as i have no room to work with LOL
can i just pour it in instead?
