Sail Panel Emblems
Old Jul 3, 2012 | 02:36 PM
halakahiki's Avatar
Default Sail Panel Emblems
My sail panel emblems for the '74 came. They look gorgeous. However, they are the 2-post variety and unfortunately the posts do not match the actual holes on the sail panels of the Monte.
Any idea how I can remove at least one of the posts?
Superbummed out by this.
Old Jul 3, 2012 | 03:03 PM
A Dremel cut off wheel, hacksaw, maybe even a pair of sharp wire cutters. Maybe you could carefully grind it off with an angle grinder or a bench grinder. Also what about making an additional hole in the sail panel to match it up with the emblem.
Old Jul 3, 2012 | 07:45 PM
I'd say use a bench grinder or a dremel. But very carefully. Or you could drill a new hole.
Old Jul 3, 2012 | 07:51 PM
Dremel works the best just be careful
Old Jul 3, 2012 | 08:12 PM
Or you can buy the ones with adhesive on them - My key chain I made I bought 73 Sail Panel emblems from some place online and it's stick=on
jimsmonte80
Apr 22, 2015 10:04 PM
Chris21
Jun 6, 2012 09:59 PM
turbo monte
Dec 17, 2011 11:47 AM
DuluthMonte
May 27, 2011 09:36 PM
78monteman
Jun 22, 2010 12:03 AM
