sad day
Check your transmission fluid.
The fuel gauge sending unit probably needs to be replaced. Assuming you're in a 2000 or newer Monte, there's a panel behind the backseat you can remove to pull out the fuel pump assembly.
MJClemm
Dec 4, 2014 06:59 AM
