Rough idle, and engine stalls
If its not throwing codes it may be something that is about to fail. I would check your purge vent solenoid for proper operation. The very may be running rich. I'm no mechanic but have had a lot of experience with the 2006 3.9 Lt model. I have had thousands of dollars worth of work done on a engine I ultimately replaced for a brand new 3.9l v6 and it still had the rough idle in park drive and neutral. It would stutter on acceleration and what not. It even stalled a few times with a brand new engine. I had the fuel pump replaced but never the vent solenoid which is located inside the rear driver side wheel. It regulates the fumes which helps control air to fuel ratio and rough idles. I've never been to school and scam mechanics billed me for everything but the cheapest fix. Hope your Monte is up and running.
Barnacle14
16
Jan 30, 2014 05:22 PM
7th Gen ('06-'07): Misfire and Rough Idle
fiveirontimmy
Mar 3, 2013 02:07 AM
Dispatcher7168
Oct 19, 2007 10:37 PM
