Rough idle after replacing intake gaskets.
Old May 31, 2013 | 01:14 PM
Denarius23's Avatar
Exclamation Rough idle after replacing intake gaskets.
i just replaced my lower intake gaskets as well as the upper intake and gaskets. Before i did this my car would stall while driving after it warmed up but i could put it in neutral and it would start right back up. Now that I have changed the gaskets it has a very rough idle. It ran very smooth before then. Even when i remove the oil cap it will stutter. And it even started emitting some light black smoke. Can anyone help with this problem. 2000 Monte Carlo SS series 2 3800.
Old May 31, 2013 | 01:19 PM
Check all of your vacuum lines first.
Old Jun 4, 2013 | 06:14 AM
03SSLE's Avatar
Double check the injector wiring and make sure you didn't accidently get a couple of them mixed up. Also check the connectors on the IAT and MAF sensors.
duster413
17
Jul 9, 2013 02:02 PM
Furder2010
Apr 29, 2013 02:23 PM
95montecar
Jan 30, 2013 01:26 PM
Jomao_o
May 28, 2012 07:25 PM
Flying Miss Daisy
Dec 20, 2009 08:03 PM
