7th Gen ('06-'07): resonator
I was just curious if any knows the dimensions for the resonator 2.5 or 2.25 I'd like to replace I it with a slp resonator and it only comes 2.5. Wanted to know how much jimmy rigging I needed to do. thanks
I believe your stock size is 2.25..
Its simple enough to use them sleeves they sell at the auto parts stores.. Youll need two
2.5id into 2.25od
That way the SLP resonator will slide into the sleeves, then the sleeves slides into your stock exhaust= 0 restriction.. Not that the edge of a pipe would cause much restriction but still.. Thats the way to do it..
Then either weld or clamp..
2.5id into 2.25od
