Replacing Transmission
Old Aug 20, 2006 | 10:29 PM
Gr4v3_7's Avatar
Default Replacing Transmission
For anyone who has had their trans replaced, how much did it cost you? Mine dosent feel to good, and I fear it will need to be repaced.
Old Aug 20, 2006 | 10:50 PM
InTheIROC's Avatar
Default RE: Replacing Transmission
What year?
A lot of transmission shops will take it for a free test drive. I'd make sure it's the transmission before you go toss a new one in. How is the fluid condition? What's the transmission doing (or not doing) that makes you think there is a problem?
Old Aug 20, 2006 | 11:46 PM
Gr4v3_7's Avatar
It is a 2000 SS. I aint gonna get a new one put in until I know for sure its that. I think it could be the trans because when I drive, and come from a dead stop, the engine revs up to about 2500RPM, then it jerks real bad, and it goes down in RPM's, then when I go again, it does the same, goes up o high RPM's, then jerks, not as bad as going into 2nd, but still noticable. I got the trans flushed when I got the car about 4 months ago, it has about 85K on it. The trans felt awsome when it got flushed, but now, it's pretty bad. Just wondering how much it cost other people, or if someone knows it it is another problem.
Old Aug 21, 2006 | 12:46 AM
White05LT's Avatar
I believe there was a TSB about this, something regarding the valve bodies in gears 1 and 2. Look into this, perhaps this is your problem. The repair may be cheaper than replacing a tranny.
Old Aug 21, 2006 | 01:53 AM
Gr4v3_7's Avatar
Sweet, thanks. NOw the only problem is I just came down to school, and I am 5 hours away from my mechanic. Oh well.
Old Aug 21, 2006 | 03:46 AM
mickey's Avatar
yeah i hear ya but the good news is there are other mechanics and if needed for school you can find another good one there to it would make your life easier then trying to limb it back home for stuff while in school.
And if they are both good they can talk to each other on the car sometimes two is better then one.
Gr4v3_7
Apr 12, 2006 04:30 AM
big green dog
Jan 28, 2006 04:15 PM
Eyedea
Jun 23, 2005 04:48 AM
bk4256
Mar 28, 2005 06:37 PM
sporges
Mar 25, 2005 12:29 AM
