replacing 6cyl with a 350 small block in an 81 monte
Old Nov 4, 2010 | 05:38 AM
scott.r.gray's Avatar
Question replacing 6cyl with a 350 small block in an 81 monte
what all do i have to change when replacing my 6 cylinder engine with a 350 small block in my 81 monte. also where is a good place to find the 350 to replace it with?
Old Nov 4, 2010 | 06:04 AM
Hi Scott,
Are you going to do the conversion yourself ? Do you have the tools/knowledge/garage ?
Below are some sites to check out until one of our expert member's posts their thoughts/information...Good Luck..
What is your budget for this conversion ?
Do you want a used 350 or a new crate engine ?
Please post more information, and it will help our member's, help `You Good Luck
Check out the below to get some idea's on parts/engines etc
Summit Racing – High Performance Car and Truck Parts l Edelbrock ...
Summit Racing has over 100000 performance parts for cars and trucks, available on-line. Lowest prices, fast shipping and best tech advice since 1968.
www.summitracing.com/ - Cached - Similar
Engines & Components
Wheels & Tires
Exhaust
Air & Fuel Delivery
Chassis & Suspension
Ignitions & Electrical
Drivetrain
Exterior & Accessories
More results from summitracing.com »
Engines & Components at SummitRacing.com: competition and factory ...
For engines, rotating assemblies, heads, crankshafts, pistons, rings, rods, and bearings, Summit Racing has more parts and guaranteed lowest prices.
www.summitracing.com/search/.../Engines-Components/ - Cached - Similar
Old Nov 24, 2010 | 10:52 AM
John B's Avatar
Since you are not limited by a computer this is a pretty straight forward swap. Easiest bet would be to get parts (like exhaust, etc) from a local wrecking yard and just get new motor mounts.
Old Mar 20, 2011 | 05:03 PM
lilhack's Avatar
you will most likely have to change your transmission too. all 6 cylinder trans have a different bolt pattern then one for small block v8. only one 6 cylinder transmission the one for the 4.3 litre v6 will bolt right up to v8 but will require 153 teeth flywheel..do the research before you spend a dime. you could save a lot of money by selling your v6 car and just buy a v8 car and junk the 305 and put a 350 in with a good built transmission.
Old Mar 26, 2011 | 11:54 AM
monte_nut's Avatar
NO don't buy a new car i just did a swap on mine about a month ago. I am assuming you have 3.8 liter V6. once you get a motor and tranny, cause urs will not work it is as simple as changing some motor mounts and dropping it in place, i advise putting the motor and tranny in as a whole. you will have to redo ur exhaust but that is no big deal.
Old Sep 20, 2011 | 10:32 AM
1987Aerocoupe's Avatar
You will need to change to different coils in the front.
Old Sep 21, 2011 | 02:55 AM
Jinx's Avatar
Oh, yes there is a computer! Than why is there a wire coming off my choke.
I had to have a swap in my '83 Cutlass and eliminated it.
Old Sep 21, 2011 | 03:02 AM
Jinx's Avatar
Ooops wrong poster!
bbyblue74
Jul 16, 2023 12:16 PM
johnmxh
Oct 5, 2009 05:07 PM
BeachBumMike
Apr 7, 2008 08:39 AM
BeachBumMike
Oct 8, 2006 08:59 PM
