5th Gen ('95-'99): Replaced thermostat now car runs cold
Old Oct 29, 2020 | 12:12 PM
SuperCracker98's Avatar
Post Replaced thermostat now car runs cold
I need a little help determining the problem that is happening here, I just replaced my thermostat last night after the previous one got stuck open and after the repair was completed and the coolant was replaced, I took the vehicle for a short 30min drive around town and I pushed it hard to see if the thermostat is functioning as it should (I tested it in boiling water and it worked). During the drive, the thermometer on my dash never rose above 120*F even though the new thermostat is rated at 180*F. I’ve bled the system of any air and topped off the coolant and my heater was so hot it could literally cook a steak but yet the temp remained the same. I’ve even felt the top radiator hose and it was hot to the touch. Could this be a false sensor reading or something more serious?
Old Oct 29, 2020 | 10:11 PM
It's most likely the temp sensor. If you are getting heat and everything is opening fine.
You never indicated what year or engine you are working on here?
Old Oct 29, 2020 | 10:15 PM
Sorry my bad should have mentioned that, 97 with 3.1L V6
Thank you for the reply though, i figured that was the case
Old Oct 30, 2020 | 08:21 AM
Jeffs02rwdSS's Avatar
Most vehicles require a 192-195 thermostat. The computer system usually goes into closed loop at 180 so odds are it will also affect fuel mileage because it makes the vehicle run rich and dump excessive fuel into the engine. This might not apply to some car's but does involve most. Unless you computer has been programmed it's not advised.
Old Oct 30, 2020 | 11:26 AM
I'm pretty sure the 3100 only needs to be 120-130 and running to 10+ seconds to go into closed loop.
I would lean towards a bad sensor or your gauge in general. Was your gauge reading correctly before the thermostat swap?
umbreonix
Feb 9, 2014 05:15 PM
HoustonChevyBoyz
Jan 7, 2014 10:58 AM
bama_z34
May 31, 2011 11:10 AM
Cheeko
May 24, 2011 01:08 PM
wildchild00
Jan 22, 2007 05:37 PM
