Removing/ installing engine.
Old Oct 26, 2014 | 04:00 PM
KMC's Avatar
KMC
Default Removing/ installing engine.
Hi, We got a new engine for my daughters car, the boys are disconnecting everything to remove the old engine , They are having a small issue trying to get the exhaust off the headers, and the ac lines.......... can u share any tricks to make it go quicker. what are the tools for the ac lines........I ll google what I can. but info from someone that's done it would be awesome. thanks in advance..
Old Oct 26, 2014 | 05:44 PM
What Make Model year motor etc.....?
The more info you provide the more info can be given..
I know were really good at providing any and all thing Monte Carlo as far as help and info..
But...
Were not psychics...
Just kidding...
We can gladly help with more info.
Old Oct 26, 2014 | 11:15 PM
nitehawkjcb's Avatar
If it's a FWD Monte,
Disconnect battery and disconnect necessary wiring connectors. Unbolt the wiring harness from the firewall, remove axles, remove throttle cables, and unbolt the downpipe... Unbolt the engine mount, trans mount, and dogbones and it should come out. I'm sure I'm missing something, but that's the jist of it.
Old Oct 29, 2014 | 01:58 AM
KMC's Avatar
KMC
Fak i just lost everything i said . If u look on bad luck on the welcome forum you will see more info . Sorry battery dying .. They got it out anyhow with a few problems but have to change some stuff around on the other engine ..
File Type: jpg
Old Nov 21, 2014 | 10:24 AM
KMC's Avatar
KMC
So my son is having some problems finding parts that connect up, the ac pump is missing and the power steering pump is missing, as well as a pulley,
> finding the part numbers to match these up has been a issue .
the stamp on the block is 24507253.
Car is a 03 monte carlo, SS 3.4 SFI
Old Nov 21, 2014 | 07:33 PM
turbo monte's Avatar
A 03 monte carlo ss never came in a 2.4 only a 3800 v6
Old Nov 22, 2014 | 12:40 PM
KMC's Avatar
KMC
Default 3.4 ltr - V6 sorry ill correct that .
Sorry for the error . We are trying to locate the a c pump and ps pump and pulley off the new engine . But having problems identifying the engine since its different . Ive got the cast number , tried crossing it with gms cast number . Theres a number on the bracket . There used to be a site that would tell you everything in your vin . This is a S series from the stamp on the cast . Now to find the parts!
KingWord
May 2, 2015 06:08 AM
dcm0123
Sep 7, 2012 08:46 PM
One Dark SS
May 14, 2010 09:26 AM
krazy92rs
Apr 5, 2005 04:35 AM
