Relearn After Overkill PCM Install?
Old Jul 10, 2012 | 11:34 PM
xxtheshockerxx's Avatar
RED DEVIL
i have an overkill tune and the relearn takes about 5 min or less with a scan tool. infact i just did it today
Old Jul 10, 2012 | 11:35 PM
Crusader SS's Avatar
If you have to take it to the dealer for the re-learn what do they usually charge for this?
At the Chevy dealer here in Canada it is $115...
Old Jul 10, 2012 | 11:38 PM
RED DEVIL
thats a rip off for virtually no work. you let the motor warm up and rev to the fuel cutoff around 4000-4500. that's it. it is just getting your hands on a scan tool that can do it.
Old Jul 10, 2012 | 11:41 PM
I agree with you... The point is though, that the re-learn is usually not necessary at all after his tune unless it throws a code...
Old Jul 10, 2012 | 11:42 PM
OK Zach, exactly what kind of scan tool is needed, which did you use? I know this doesn't actually pertain to me, but I was thinking of getting it for my 3.9 and I would most likely have the same issues?
Old Jul 10, 2012 | 11:55 PM
RED DEVIL
I used a snap on scan tool. I borrowed it from the mechanics next door. It is like a $6500 tool I suppose you dont need something that crazy to do it. I was having some trouble with my car and initially using it to monitor my transmission
You would have a good chance to have to relearn with your car chris. I was told it is about $50 from most gm dealers but i could be wrong.
Old Jul 11, 2012 | 07:43 AM
03SSLE's Avatar
Hey Frank...
So far it looks like a 50/50 chance of needing the relearn:
'05 No
'03 No
'02 Yes
'07 Yes
I guess I'll budget a few extra bucks into the project just in CASE (pun intended).
Anyone else have the Overkill tune done?
Old Jul 11, 2012 | 08:00 AM
MAMONTE's Avatar
I have an Overkill PCM in my Monte, and when I installed it, it needed the security re-learn, which I was able to do with the instructions provided. However, I also had a check engine light thrown, and the code was for a crank position relearn, which Will made me aware of before selling me the PCM. He said it doesn't always happen, but it could. The crank relearn I had to have completed at a shop. The overall cost for the crank relearn was about $80 bucks if I recall. After getting the crank re-learn done, I had no problems after that and it runs AWESOME with the tune. I highly recommend the tune if you are looking to get more power, and better shift points.
Old Jul 11, 2012 | 09:21 PM
'05 No
'03 No
'02 Yes
'07 Yes
Sorry Mike...:p
Old Jul 11, 2012 | 09:31 PM
My bad... I thought we were talking about the Crank re-learn (there is also another name for it, can't remember right now), that was what I took it to the dealer for and it was not necessary... The security re-learn will absolutely be necessary as it is part of the installation of the new PCM... If I remember correctly, I had to do it twice because of very little patience in following the instructions... When you do it, word of advise follow the instructions to the letter...
