6th Gen ('00-'05): Rear turn signal problems (replaced bulb, worked, then stopped again)
Old Jul 21, 2017 | 09:02 PM
mjaram's Avatar
Default Rear turn signal problems (replaced bulb, worked, then stopped again)
Hey all.
the turn signal on the dash was flickering real fast.
i saw my rear driver side signal light not working.
i replaced the bulb and it worked fine for 2 days.
now again I'm getting the fast flickering on dash and the rear driver side signal light is not working again.
i have yet another bulb but worried it's just going to do the same thing again. Anyone have any similar issues that they resolved outside of replacing the bulb?
thanks
Old Jul 21, 2017 | 09:44 PM
plumbob's Avatar
Check the connection to the bulb socket. Wiggle the wire with the signal on to see if it makes a difference. Clean or replace the connector if it does.
