Rear turn signal problems (replaced bulb, worked, then stopped again)
Hey all.
the turn signal on the dash was flickering real fast. i saw my rear driver side signal light not working. i replaced the bulb and it worked fine for 2 days. now again I'm getting the fast flickering on dash and the rear driver side signal light is not working again. i have yet another bulb but worried it's just going to do the same thing again. Anyone have any similar issues that they resolved outside of replacing the bulb? thanks |
Check the connection to the bulb socket. Wiggle the wire with the signal on to see if it makes a difference. Clean or replace the connector if it does.
