6th Gen ('00-'05): Random Mis-Fire, only when turning right?
Old Aug 15, 2020 | 11:34 AM
kenneyjuice's Avatar
Default Random Mis-Fire, only when turning right?
Alrighty guys, here's an interesting one.
2005 SS Tony Stewart Edition 107,XXX miles.
So for about 8 months whenever I steer right while driving my car stutters, like it's going to stall but never does. This is mainly happening while on on‐ramps or off ramps. While this happens my car throws the P0300 (random misfire). It feels like a bad vacuum leak but once I straighten up the car feels fine and the engine light stops flashing. I tried to replicate this with the car on jack stands, but I couldn't, it seems fine with no load and steering right. Initially I took my car to a shop and they said that I needed a new computer, so I replaced the PCM with a ZZP one, the issue remains.
Here's a list of things I've replaced.
Plugs/Wires
ZZP Coil Packs
MAF sensor
TPS (Throttle Position Sensor)
Idle Air Control Valve
Fuel Filter
Vacuum Lines
Catalytic w/ 02 sensor
At this point, I'm thinking that theres an electrical issue, maybe something grounding out? If you guys can think of something or have even heard of a similar issue, please let me know! Thanks in advance!
** Forgot to add that while my car is mis-firing, my tachometer is acting crazy, dancing all over the place**
Old Aug 20, 2020 | 12:22 PM
Question
I just got TorquePro, so I was able to get a screenshot of some numbers...
Old Aug 23, 2020 | 03:25 AM
Mike85120's Avatar
I was going to say fuel pump issue until I saw the tach going crazy when it occurs.
When gas gets pushed to one side when taking a corner and the pump is either damaged, on it's way out or installed incorrectly it can cause a studder from fueling issues.
Possibly a short that is grounding out when the force from turning makes the wire in question ground out.
The wire bundle is shifting to one side in other words.
I think the tachometer has a wire that goes to the transmission.
Check there as a possible starting point.
The short itself might not just be the tach grounding, the wire bundle has another wire that is making the computer freak out too.
A couple of frayed wires could be the culprit and probably is going to be just the one bundle.
I am not an expert but this sounds feasible.
Old Aug 23, 2020 | 08:43 AM
All I can add to this is the tach has a white wire going into the PCM.
Could it possibly be a wheel hub going back causing TC to kick in while turning?
WolvenScout
Mar 18, 2019 06:57 PM
Carbon95
Dec 18, 2018 07:25 PM
1996Monte_Carlo
Jan 27, 2012 04:30 PM
radiantdragoon87
Aug 16, 2011 10:10 PM
llooney18
Dec 29, 2010 01:26 PM
