6th Gen ('00-'05): Radio problem.
Old Dec 4, 2016 | 09:49 AM
Cyclok's Avatar
Default Radio problem.
Hey guys. My radio has a bit of a problem. It turns on works but no sound comes out. No hissing or static even plays through the speakers. Anyone had this happen before? Any suggestions?
When do you guys suggest a PCV valve replacement? I will be doing LIM and valve cover gasket replacements within the week and I was wondering if I should get a new pcv.
Old Dec 4, 2016 | 11:44 AM
WBody's Avatar
Start seeing if the speakers get signal. I'd personally just change the valve because they are cheap and I like to do extra so I don't have to work on it later - especially since I am in an apartment so the vehicle is outside and not always available to work on; the entire weekend has been rainy in TX for instance.
Old Dec 4, 2016 | 11:53 AM
Cyclok's Avatar
Originally Posted by WBody
Start seeing if the speakers get signal. I'd personally just chance the valve because they are cheap and I like to do extra so I don't have to work on it later - especially since I am in an apartment so the vehicle is outside and not always available to work on; the entire weekend has been rainy in TX for instance.
I'm lucky and live in a condo with a parking garage. I just need permission from management to take apart my engine for some reason. Probably fluids they're worried about. I'm going to head down and see what's behind the dash radio-wise.
Old Dec 4, 2016 | 12:11 PM
WBody's Avatar
Keep us posted. Also what radio setup do you have? Does it have an amp?
Old Dec 4, 2016 | 02:47 PM
plumbob's Avatar
Could be a couple different problems usually amp. related.
1. Check the fuse for the amp.
2. Check wiring at the passenger side door sill for a short.
Videos:
Old Dec 4, 2016 | 03:12 PM
Cyclok's Avatar
Thumbs up
Videos:
https://www.youtube.com/watch?v=7K1KEdxugyU
https://www.youtube.com/watch?v=lNlSSXF6PKQ
Plumbob that's totally it. Although I have to remove the bottom part of seat belt and the rear passenger snap on cover is way bigger, I found the problem. When I get to work I can replace the wiring with the correct Guage. Appreciate the help
Old Dec 4, 2016 | 03:18 PM
plumbob's Avatar
Glad it worked out
