radiator drain plzzz help
Old Sep 21, 2010 | 02:18 AM
dwnsoufsailn's Avatar
Default radiator drain plzzz help
83 monte. The wing type nut wnt go up as I try to screw it on.... did I fk it up
Old Sep 23, 2010 | 09:06 PM
seawolf18's Avatar
Are you trying to remove the drain, or put it back on? On the older cars, they are brass and easier to use than the newer cars with the plastic ones. If you screwed the wing nut up, you can just replace it with the same size bolt.
I don't try to use the plastic wing nut drains on the newer cars, since I broke one once trying to undo it. I just take the lower radiator hose off now.
Old Sep 24, 2010 | 06:27 PM
I Was trying to tighten it...I bent the wing and un screwed it wit a ratchet n jus replaced it wit a new one frm carquest
wnmech
Nov 4, 2013 06:24 PM
krakabash
Sep 20, 2010 06:11 PM
monteario03
Jan 20, 2009 08:23 PM
joesumrall
Oct 25, 2007 09:47 PM
montess_24fan
Jul 14, 2007 03:50 AM
