proud new owner
Old Aug 5, 2007 | 03:35 PM
cheezymac's Avatar
Default proud new owner
hey guys, i am new to this forum and just bought a 2000 white monte carlo. it is used and has a couple flaws. 1 the door ajar light stays on and the dome light does not work. how do i fix this guys?
Old Aug 5, 2007 | 06:39 PM
mickey's Avatar
Default RE: proud new owner
most likley they are cused from the same issue. check the bulb in the dome light they might have taken it out or it has burned out or the fuse was pulled due to the door not turning it off.
the fuse for it is on the pass. side of the car.
there is a switch that tells the car when the door is shut if it is not working it is the reason for it to not turn out the warrning lights and dome lights.
the switch is located in the front of the door
get a chiltons book and it will show you exact location
Old Aug 5, 2007 | 06:57 PM
Welcome Charles, to the MCF
What model 2000 Monte do you have ?
Post some pictures when you can : )
Moderator `Mickey gave you some good area's to check.
Look forward to your future posts.
`Space
Old Aug 5, 2007 | 07:06 PM
wiz kidd's Avatar
hey welcome to the site,
i think your problem is probably the door jamb switch
GaJItt
Oct 5, 2013 07:30 PM
crusher38
Jun 14, 2013 01:20 PM
2006MONss
Mar 6, 2013 01:14 PM
iMuf
Jan 15, 2013 06:45 AM
GrandPaDave
Sep 28, 2011 01:02 PM
