Problems starting
Old May 26, 2014 | 01:35 PM
dminoradd2's Avatar
Default Problems starting
I've just gotten a tune up [plugs / wires] and still having problems starting it . The check engine light does not come on so I don't have a code and fuel mileage is still down maybe 20 miles to the gallon or less please help
Old May 27, 2014 | 07:27 PM
Nightmagic11801's Avatar
have you changed your fuel filter lately? if its clogged you may not be getting enough fuel to start it. if you can, have someone check your fuel pressure to make sure your getting the proper amount. if after you change the filter the problem still persists, i would have the pump checked. could also be a bad ground wire.
Old May 27, 2014 | 07:54 PM
Hiroska's Avatar
The models before 06 have a fuel filter to remove? That's interesting. What does it do when attempting to start?
connersdad19
May 18, 2009 07:51 PM
thunderoad02
Jun 11, 2008 08:21 AM
jamiew
Sep 17, 2007 12:39 PM
lcmontecarlo
Sep 21, 2006 03:43 PM
