Problems with Antifreeze
Old Apr 23, 2011 | 02:39 PM
linkdude240's Avatar
Default Problems with Antifreeze
Hey all, I am the proud owner of a '95 Monte Carlo z34 beast with a horrid anitfreeze leak that has eluded me and my dad for about a year and a half now. We have previously replaced the heater core, and due to time constriants and a strangely fitting part we had to kind of shove a plastic hose on (that was around 5 years ago) and we had thought the hose had come off, but upon tightening it and refitting it better, there is still no change. The leak appears to be coming from under the engine behind the exhaust manifold, and we suspect it to be a cracked head. There are also some corroded pipes that could be a contributing factor.
Can someone who had a similar problem point us in the right direction?
Thanks in advance.
Old Apr 23, 2011 | 03:49 PM
Gthirteen's Avatar
check the oil for antifreeze in it or the water for oil but i had the same problem and it was on a 1995 monte carlo ls with 3.1 and it turned out to be the intake manifold leaking down the backside of the engine.
Old Apr 24, 2011 | 02:47 PM
Thanks a lot. I also heard of an alternator braket leak, and we have had the alternator done multiple times, so will reply once we get conclusive evidence.
Old Apr 26, 2011 | 10:18 PM
Justin Knight's Avatar
The 3.4l DOHC engine might make respectable power for a v6 bit is a turd in the gm v6 family which is why it didn't last a long time. A head could be cracked or an external gasket leak. Coolant doesn't always end up in the oil or oil in the coolant, or coolant out the exhaust pipe. Sometimes it's just a straight up external leak. I suggest swapping a 3800 in or just keep the coolant full in your 3.4 dohc and check the coolant and oil every 2 weeks or 500km's.
My opinion might be slightly biased as I hate, that's right hate the 3.4 dohc engine.
Old Apr 4, 2013 | 10:09 AM
gizmomartin's Avatar
Default Antifreeze leak on 95 monte
I had this same problem bout 8 yrs ago on mine. so I pulled the engine and rebuilt it all the way through. turned out to be a leaking intake gasket of which coolant got into the engine through the exhaust stroke. I know the 95 3.1 are nortorious for intake leaking at 50,000 miles or so. now 8 yrs later on this still new engine with only 49,000 miles on it. It has a problem with leaking coolant down behind the engine. my quess is bad intake gasket (again) leaking out down the backside of my engine. looks like im pulling it again !
Old Apr 9, 2013 | 11:04 PM
2003_iceman's Avatar
Exclamation
since when was a gm 3.4l v-6 a dohc??? would love to know that one. and 13 years experience yeah i can fix it. you are not working on my car if you think the 3.4 is a dohc when it's a push rod engine
Old Apr 9, 2013 | 11:06 PM
why pull it and rebuild it again? see if you can get the aluminum gaskets and get rid of those nylons. shouldn't have a problem outta that intake after that
Old Apr 10, 2013 | 05:32 AM
First, during the mid-90's GM DID have a 3.4 v6 DOHC (this is NOT related to the 3100 or 3400 engines you are probably thinking of). Google Image search it and you will find it.
Second, this thread has been dead for 2 years.
Old Apr 11, 2013 | 02:12 AM
Mpeterson's Avatar
I think you should examine the oil for antifreeze in it or the water for oil but i had the same issue and it was on a s5620 carlo ls with 2.7 and it became the consumption numerous dripping down the rear of the motor. . . . . . . . . . .
05SSMonteCarloSC
Feb 26, 2010 07:51 PM
jasonmcr
Feb 27, 2008 07:43 PM
Sir Monte
Feb 20, 2008 08:08 PM
hotrodss24
Dec 24, 2007 09:58 AM
87lsman
Jun 6, 2007 01:56 AM
