Power Steering Return Hose Clamps
Old Nov 3, 2011 | 03:28 PM
jasonsmith's Avatar
Default Power Steering Return Hose Clamps
I was looking at flushing the power steering fluid on my 02 Monte 3.4L. I was going to replace the power steering return hose as well, but noticed it had that single use clamp on the top part of the hose. Do you just use cutters to cut the part that sticks out on the clamp? Not really sure how to get the upper clamp off.
Can you use a worm gear clamp on the lower part of the hose? Not sure if there is room for the screw driver or socket to get to a worm gear clamp compared just using the OEM spring clamp.
And I'm assuming the hose is 3/8"?
WImonteman
Apr 13, 2014 09:12 PM
texascardude
Jan 31, 2011 08:29 PM
Clueless
Dec 16, 2010 01:29 PM
gforcems
Feb 12, 2008 12:33 AM
