power steering belt
Old Sep 21, 2010 | 09:11 PM
dwnsoufsailn's Avatar
Default power steering belt
How do I remove the power steering belt I can't find a way to loosen up the tension
Old Sep 21, 2010 | 11:12 PM
nitehawkjcb's Avatar
There's a tensioner somewhere around the pulleys. Use a ratchet and the tensioner moves, putting slack in the belt, allowing you to remove it.
Old Sep 22, 2010 | 09:00 AM
Stevis's Avatar
he probably has a V belt setup.....which wouldnt have a tensioner...
does your PS pump look like it's adjustable? or is it the same belt that runs the alternator? one or the other should have a bolt in a fixed location, and another that goes in a slotted mount...so you can adjust the tension that way....
TomF106SS
Oct 6, 2014 10:13 AM
MJClemm
Oct 29, 2012 06:14 PM
01blackmonte
Oct 17, 2005 07:30 PM
tundra
Aug 15, 2005 05:24 PM
