power mirror switch problem
Old Nov 26, 2004 | 09:55 PM
kevin187's Avatar
Default power mirror switch problem
my driver side window was having problems going up so i took my door panel off to see what was goin on and it looks like it just needs greese where metal is rubbing on metal but when i took off my door panel my green wire from my power mirror switch came out and i took out the switch to look at it and the wires are all in some kind of gel stuff so i cant re-connect my green wire again........would it be ok to dig out all the yellow gel to connect my wire? because im thinking that a new switch would be kinda expensive.
Old Nov 26, 2004 | 11:35 PM
montejass's Avatar
Default RE: power mirror switch problem
Kevin,
I would if I were you. At this point, what do you have to lose? I would be willing to bet that gel is corrosion preventative grease.
Let us know how it goes.
TVW
Old Dec 12, 2004 | 12:18 AM
kevin187's Avatar
haha my ghetto engineering skills came though on me on this one. i got worked out
robknight13607
Nov 20, 2016 01:24 PM
zwaldo
Apr 21, 2014 08:58 AM
AJMDowling
Oct 18, 2012 09:11 AM
espo83
Oct 7, 2009 03:54 PM
cain45
May 22, 2007 12:34 PM
