Possible vent problem
Old Aug 16, 2010 | 11:53 PM
70monte1's Avatar
Default Possible vent problem
Tonight while driving the car with the windows down and the
AC off, it felt like warm air was coming out of the vents. I had the blower switch in the off position and the air selection in the upper vent spot. None of the lights in the AC/heat control were lit.
Driving down the road, the air outside felt cool but the air coming out of the vents felt a lot warmer, almost like it was getting hot air from the engine compartment.
Is there a way to tell if the AC/heating panel is malfunctioning? Thanks.
Wayne
Old Aug 17, 2010 | 01:42 AM
Beautikill.2000monte's Avatar
na its normal, probably just never noticed it before. switch the vent to defroster when your not using it and youll never notice it agian.
Old Aug 17, 2010 | 05:14 AM
70monte1's Avatar
Ok thanks, I will try that.
Wayne
Old Aug 17, 2010 | 08:24 AM
I would turn it down to your feet, I try to keep off the defroster setting as much as possible while not using it. But normal.
Old Aug 17, 2010 | 05:19 PM
out of curiousty how come you recommend not using defroster, or is it just prefrence.
klkline50
Dec 6, 2014 11:37 PM
knappstr
Dec 4, 2011 10:09 PM
jessymo
Feb 19, 2009 10:07 PM
Fusiform
Sep 5, 2007 01:51 PM
redneckmc
Oct 1, 2004 09:39 AM
