possible issue
It's usually a tell-tale sign of a bod core BUT it could also be a coolant leak under the hood moving the smell in through the fresh air intake.
Time to pressure test.
BTW - If it is, i'll sell you a heater core from my '04 with 62,000 mile on it, not used in winter since I got the car in '08. There is nothing wrong with it, I changed it because to change the evaporator core for my A/C I had to remove the HVAC module that holds both cores. I'd NEVER have an easier time doing the job (though doing the heater core would be much easier then the Evap core, no need to remove the HVAC module).
6th Gen ('00-'05): friends monte issue now my issue
thtGuy
May 7, 2013 08:09 AM
Cowboy6622
Jan 25, 2011 06:27 PM
jessymo
Feb 19, 2009 10:07 PM
