PCM location for 2000 Monte Carlo L36
Old Nov 7, 2010 | 04:06 PM
el402's Avatar
Default PCM location for 2000 Monte Carlo L36
I'm going to be sending in my PCM to ZZP to flash, thing is I don't know where it's located in the car. I have a 2000 Monte Carlo with a L36 engine.
In case you're interested I just purchased a SLP exhaust system and will be ordering a ZZP downpipe and maybe a cai. As mods for the engine that'll be pretty much it.
Anyways, if anyone can help I'd much appreciate it as I'd like to send it out to ZZP tomorrow.
Thanks
Old Nov 7, 2010 | 04:46 PM
mrl390's Avatar
The PCM is located on the drivers side below the air filter.
Old Nov 7, 2010 | 04:49 PM
el402's Avatar
Thanks mrl390. I'll check it out tomorrow when there's more light outside. Any pointers on how to remove it?
Old Nov 7, 2010 | 05:53 PM
mrl390's Avatar
Cant help you there. Mine is in a different location. Never removed one from a 6th gen, just know where it is.
jarheadbobandmax's Avatar
Photobucket
inside the box below the filter
Old Nov 7, 2010 | 06:40 PM
el402's Avatar
Thanks all. Before I disconnect the PCM do I have to disconnect the terminals from the battery first?
Old Nov 7, 2010 | 06:54 PM
your advised to remove the negative battery post, its within the air box, if your taking the air box apart you will see it on the bottom, its a little silver looking box thing, it's pretty easy to get to
Old Nov 7, 2010 | 08:13 PM
el402's Avatar
Thanks all for the help and tips. This is when I wish I had a garage so I could work on the car. Oh well, tomorrow when there's light
jeffrae
Feb 20, 2017 10:02 PM
dgm
Sep 22, 2014 10:15 PM
Chris s
Jan 26, 2013 04:49 PM
The_Maniac
Nov 10, 2010 09:42 AM
scortch
Jul 11, 2005 04:10 AM
