Passenger side vents blow hot air with AC on?
Old Oct 9, 2013 | 03:25 PM
joe34's Avatar
Default Passenger side vents blow hot air with AC on?
Have a 2003 Monte Carlo SS 3.8.
When sliding the drivers side heat, Ac blend bar to the AC section, works great, but when sliding the passenger side bar to AC it blows hot air?
Old Oct 9, 2013 | 05:11 PM
ndaguanno's Avatar
The blend door for the passenger side is most likely the culprit, you can attempt to tap the blend door motor with a screwdriver, sometimes it will get a little more life out of it. You'll end up replacing it eventually. Something I've always done in my car, is adjust the temperature one side at a time, no radio on, no blower, you should be able to hear it adjusting if it isn't then you know thats your problem. I can always hear mine switching when I go from hot to cold or vice a versa. Little troubleshooting tip without having to remove anything, I think its common for those to go out though.
Old Oct 9, 2013 | 05:19 PM
l0gitech87's Avatar
ndaguanno x2
Old Oct 10, 2013 | 10:33 AM
joe34's Avatar
Thanks! nadaguanno.
I will give that a try.
cool77
Jul 4, 2016 07:36 PM
fishm3at
Nov 20, 2013 08:01 AM
Feb 1, 2013 07:35 AM
kanianic
Jan 1, 2011 07:03 PM
sunshine1979
Oct 28, 2010 06:50 AM
