P0171
Old Feb 20, 2013 | 08:16 PM
brian99_03's Avatar
Default P0171
My check engine light came on on my 2005 Chevrolet Monte Carlo LS & the code was p0171. I took it to a mechanic & was told that I need to replace my upstream O2 Sensor. Once replaced, the code was reset but, not even a mile down the road, the light came back on. I took it elsewhere & was told that, had it been my O2 Sensor, the code would've specified O2 sensor but it was just reading bank 1 too lean which means that possibly a cracked or leaking hose somewhere around the intake. I'm not sure what to do...Help!
Old Feb 20, 2013 | 08:50 PM
03SSLE's Avatar
It's possible you have an intake leak (vacuum leak), but I would check the MAF sensor first. If it is dirty or malfunctioning it will set the P0171 code. So will a bad fuel injector, faulty PCV system or a problem with fuel distribution. The MAF would be the first thing I'd check though.
Old Feb 20, 2013 | 10:06 PM
Also If its burning antifreeze.. (contaminated the o2 sensor)
yeyeee01
Dec 8, 2018 10:26 PM
matt210
Jun 11, 2012 06:08 AM
1FasImp
Aug 30, 2011 10:51 AM
Sparky-88
Jul 12, 2011 03:28 PM
