P0171 in 3 miles
Old Apr 12, 2015 | 05:47 AM
  #91
avendo's Avatar
yea nothing around there...like I said pinching off that line brings stft down to 0%..that tells me that's the area of the problem...
Old Apr 12, 2015 | 08:53 AM
  #92
plumbob's Avatar
Let us know what you find
Old Apr 13, 2015 | 09:24 AM
  #93
avendo's Avatar
still get .65-.75 on bank 1 sensor 2 O2 sensor,no change really.. and still got 16% LTFT..What does that solenoid do?
Old Apr 13, 2015 | 11:20 AM
  #94
avendo's Avatar
well I got my 3/8 wrench out and found the intake bolts loose on the front side of the eng..my friend wrote me this
That's the fuel pressure regulator. Low or no vacuum high pressure, high vacuum low pressure. High fuel pressure means more fuel so low long term fuel trim. Probably not your problem area. I still think your problem in the intake gaskets. Should do those then recheck fuel trim.
Old Apr 13, 2015 | 03:27 PM
  #95
avendo's Avatar
now after drivin around today...stft is 20% O2 1-1 is .060 and )2 1-2 is .040..it only moves when I pinch off that line and then the 02 1-1 looked normal.. when I reved it up it blew smoke..
Old Apr 13, 2015 | 06:33 PM
  #96
avendo's Avatar
I got scanmaster elm on a cd with the elm327 and it has a crack,but it didn't work...
Old Apr 13, 2015 | 07:01 PM
  #97
avendo's Avatar
seems worse now,20% stft and it doesn't even go down much when I rev it up and the o2 sensors are not acting right..
Old Apr 13, 2015 | 08:11 PM
  #98
plumbob's Avatar
Smoke is a sign of a clogged Cat. Use the Cataclean then check the results. If the Cat is inefficient emissions will build up.
Old Apr 13, 2015 | 09:03 PM
  #99
avendo's Avatar
I just ran car cleaner through it yesterday..
Old Apr 14, 2015 | 05:12 PM
  #100
plumbob's Avatar
Do you still have P0420?
