P0171 in 3 miles
Old 03-11-2015, 06:32 PM
avendo's Avatar
Default P0171 in 3 miles
I pull the car from storage after month and a half,stupid 100 inches of snow..shut off eng light with 171 code,go to get haircut 3 miles away..come out and light is back on,already looked for vaccum leak,new plugs wires,o2 sensor maf...not GM ...what could set it of so fast...
Old 03-15-2015, 07:03 PM
avendo's Avatar
is there a o ring on pcv on s/c cars?
Old 03-15-2015, 07:31 PM
supposed to b,e. but I didn't get one when I bought pcv either
how did you look for vacuum leaks
Old 03-15-2015, 07:36 PM
plumbob's Avatar
Did you change both O2 sensors? Was the car outside in the snow above the level of the gas cap? Even a small amount of water in the fuel can cause a lean exhaust to be indicated. The PCM will clear the MIL after the third consecutive passing trip. The history DTC won't clear until there has been 40 consecutive warm-up cycles.
Old 03-16-2015, 04:56 AM
avendo's Avatar
I but I only changed the upstream 02 sensor I sprayed everything for vacuum leaks had a vacuum gauge on it and read 19
Old 03-16-2015, 07:02 PM
avendo's Avatar
I think I found it,the vacuum that was supposed to be connected to map sensor was not connected...well it didn't seem like it,found plug off,so far I drove to get gas and few other places and it didn't come on...gross fingers.
Old 03-16-2015, 07:04 PM
avendo's Avatar
cross*
Old 03-16-2015, 09:36 PM
plumbob's Avatar
Congrats! That'll do it. Let me know if you still have probs. Got other tricks to try.
Old 03-17-2015, 05:14 AM
avendo's Avatar
It has not come on yet and I've driven a lot of miles hopefully that's the fix
Old 03-20-2015, 11:40 AM
avendo's Avatar
today the light went back on after 4 days...
Quick Reply: P0171 in 3 miles
