6th Gen ('00-'05): Overheating issues
Overheating issues
So I recently changed the belt tensioner since the heater hose that connects to it kept coming off causing coolant to be released. I've been adding coolant and burping the system for about three days now and the car is still going over the halfway temperature mark on the gauge. As far as the cooling system goes since I've got the car I've changed the tensioner, radiator, both hoses, flushed the system, the thermostat,the thermostat housing, the radiator cap, and the coolant overflow tank. No matter what I do, the temperature continues to go past normal temperature. It doesn't over heat to the point where it reaches the red box at the end of the gauge but it does go anywhere from the line just past the halfway all the way to the line just before the red box. When it makes it that far I turn the heat on and it starts to lower for a bit. It's an 05 Monte Carlo SS Supercharged is it any opinions from you guys?
I got the mechanic to look at it yesterday. He bled it for hours until the air was completely out and checked the temperature with an obd scanner and it was running max 221 then it would come back down to anywhere between 212-217 when the fans kicked in. Is this an okay temperature ?
Last I can remember it was probably late last year or early this year and I believe I put in a 195° one
My coworker was tellin me I should put in a 160° one so it would keep the engine cooler but I wasn't too sure that was the right way to go
After attaching it you let the car idle in either a flat spot or with the passenger side of the car at the highest point and when you don't see bubbles in the funnel anymore you are done
I have exactly that same one lol, I put it on but my question is do I leave fluid in it and put the stopper in it as well? I have the stock supercharger yeah
What I do is pour enough fluid in it to wear it would seem overfilled to allow the air bubbles to work themselves out, however when it's all done you could suction out the remaining fluid or soak it up with paper towels or something, I'm not sure what you mean by a stop but I just tighten the funnel down and then pour the coolant in and let it idle
