Overheated, coolant bubbled and spilled out....
Old May 3, 2008 | 06:34 PM
WhipItGood's Avatar
Default Overheated, coolant bubbled and spilled out....
does anyone know what the problem might be? After getting home I was waiting for someone andI was sitting in my car when I heard bubbling. I opened the hood and coolant was bubbling and spilling out of the coolant carrier (?) and now my coolant is only half full. It's been overheating just a little bit for the last 2 weeks or so and I thought that it was just a little low on coolant (I know I know but I am not a mechanic in the least bit) but I now I'm kinda shook
Old May 3, 2008 | 06:39 PM
WhipItGood's Avatar
Default RE: Overheated, coolant bubbled and spilled out....
oh yeah and the temp needle went over the half way mark close to 3 quarters but went down after a couple of seconds
Old May 3, 2008 | 10:50 PM
purewhitemonte's Avatar
Here's some possiblities:
1. The drivebelt for the water pump could be defective or out of adjustment preventing the pump from ciculating the antifreeze
2. The water pump is bad and needs replacing
3. Radiator core is clogged inside the radiator or the grille(the mulitple thinfins that go up and down it)is restricted. Radiator core will need to be cleaned out or replaced. The fins can cleaned off from the bugs that collect on them.
4. Either cracked or broken fan blades, or bad fan (in front of the radiator).
Old May 4, 2008 | 08:12 PM
rysZ34's Avatar
Or possibility number 5 is that your thermostat needs replacing.
orthokneepa
21
Jul 9, 2019 09:19 PM
Tzarm
Sep 9, 2013 09:22 AM
the5schlueters
20
Apr 1, 2013 03:53 PM
monte carlo 3831
Aug 7, 2012 06:01 AM
Laserblue06ss
Jul 5, 2007 08:33 PM
