Oil pressuse switch to turn fuel pump on
Old Dec 30, 2010 | 07:56 PM
85monte4.3's Avatar
Default Oil pressuse switch to turn fuel pump on
ok this is crazy i figured my starting problem and found it has something to do with the oil pressure switch buuutt the part i need is no where i have a pic if you dont know what im talking about its a 2 spade switch the 1st one i got was for a 3.8l v6 the threads were to big the second 1 i got it goes to a 5.0l and has a longer cone type shape with the threads at the end which fits it still started hard but it ran and even idled fine until i went to the store and it would crank but not run untill i jumped the conntector.. by the way i did jump the connector to figure this out b4 and cranked right up with no hesitation so i looked online advance autozone napa even rock auto, the only 2 spade switch they have does not fit at all so im just going to put my old 1 back in get a switch because the fuel pump stays running after the ignition is off and some wires. this is whats stamped on the part i need "ac spark plug 0865" also the parts ppl keep asking me if its a light or gauge and i know i dont have a gauge its a light with the single wire connector which i dont need so anyone that has had this problem or heard about this give me some insight or should just wire the thing up with a toggle switch and call it a day
ReaperSS
Aug 29, 2014 11:35 AM
The_Maniac
FWD Tech Guides '95-'07
Jan 26, 2014 05:54 PM
crete
Nov 6, 2011 07:05 PM
Nortybignort
Jul 25, 2006 10:35 PM
trigger
Jun 12, 2006 04:05 AM
