oil change
Old Mar 13, 2010 | 12:14 AM
captaindamnit's Avatar
Default oil change
ok, dont mean to sound like a newb here but tomorrow will be the first time that I ever changed my oil on my own. I know im getting 5 quarts of Mobile 1, but what kind of filter do i get? I looked today and there were like 4 different sizes to get... what size? and brand if you would. Any help is appreciated!
Old Mar 13, 2010 | 12:25 AM
oem! acdelco filter? you can't go wrong with that and check? not sure on size but check the recommended filters for your car! it should not be that hard of a choice, just do the recommended? hope that helps!
Old Mar 13, 2010 | 12:30 AM
Budsjlm's Avatar
Wix is a really good filter and go to a parts store they will get you the correct one no matter the brand you go with
Old Mar 13, 2010 | 12:47 AM
i always use the best fram cause all the other frams are crap. its a very easy job. just watch out some oil is going to spill out of the filter when you take it off. i always put a garbage bag over my arm.
Old Mar 13, 2010 | 05:23 AM
RocknSS04's Avatar
I agree with everything posted above. Purolator also makes a great filter. I use NAPA Gold filters, which are made by Wix. CarQuest also has a Wix filter.
Also, get the long filter instead of the stock shorty filter. It's the one for the 4.3 V6. More filter area, same filter.
You can get 5 qt. jugs of any oil at Walmart.
mstrmysterious63
Sep 25, 2012 03:04 PM
dcnaser
Mar 25, 2012 07:40 PM
drmrgal
Apr 8, 2011 05:11 AM
04MonteLS
FWD Tech Guides '95-'07
19
Mar 10, 2011 06:14 PM
70monte1
25
Jan 19, 2010 09:04 PM
