o1 monte ss running problems 3.8 motor
Old Aug 12, 2008 | 03:39 PM
stanger's Avatar
Default o1 monte ss running problems 3.8 motor
my 01 monte will some times stall when driving any suggestions?any help will help thanks
Old Aug 12, 2008 | 03:47 PM
stanger's Avatar
Default RE: o1 monte ss running problems 3.8 motor
new here sorry
Old Aug 12, 2008 | 05:35 PM
mickey's Avatar
dose it feel slughish also? if so you might check the cat. comverter.
the other thing you might think of doignif yo havent already. add some fule injector cleaner and also might try to change out the gas filter to make sure they are not pluged up.
Old Aug 12, 2008 | 05:38 PM
2000_BLACK_SS's Avatar
is there any check engine light on? when was the last time that it had a tune up?
it could be a dirty MAF sensor becausethe same thinghappened tomy brother in his3.8 in his grand prix.
Old Aug 12, 2008 | 06:24 PM
odessadude's Avatar
Also check the throttle body. I have had two cars now that stall after starting or that were in gear at a low rpm. If it will run when you floor it, the throttle body probably needs cleaned. The ecm will shut it down if the air/gas mixture is not correct.
Just take the rubber hose off the throttle body and get some good carb/throttle body cleaner and clean it out good.
Good luck!
Old Aug 13, 2008 | 05:54 AM
tommyd's Avatar
check the fuel pressure regulater
Monroe
Jul 17, 2012 05:30 PM
monteman1980
Jun 29, 2012 04:36 PM
sdt1985
Apr 8, 2012 12:11 PM
80sselky
Sep 5, 2011 11:37 PM
ttmillus2
Jul 5, 2011 10:28 AM
