Noise from fan
RE: Noise from fan
I actually tired what 2000LS said, but didn't find anything, know signs of water coming in there, I had the blower motor out today and it seemed fine, but i put some oil in the bearing hole on the back and i'll see how that works out, if i get the noise, i guess I'll get a new one.
I also found out (i just put this car 5 months ago) the blower motor that is in it is aftermarket, so someone has already replaced it. If you remove that black plastic cover by the passengers feet, it's right there, held on by 3 screws, there's a rubber hose on the back right side and the wiring it connected at the back. There's a wiring harness for something that pissed me off on the left it was always in the way but other then that it came out and went back in good.
RE: Noise from fan
okay, if you remember this thread or for future people looking. After putting the oil in the hole on the back of the blower motor the noise when taking right turns is gone. I'm not 100% on the loud noise that started this thread because it didn't happen that often in the first place, but so far I haven't heard a peep out of it.
5th Gen ('95-'99): Passenger Radiator Fan (Fan #2) Not Turning On
gmartinez93
05-11-2015 10:45 PM
6th Gen ('00-'05): Fan Squeal/Whine Upon Startup With Fan On
jhbasse
01-15-2013 06:39 PM
