No Start Issue
Old Aug 20, 2025 | 09:16 AM
davidh0765's Avatar
Originally Posted by 02MonteSS_D.E.
Also was the new PCM programmed with the vehicle VIN as well?
Yes, it was programmed with the VIN. IT did solve the communication issue and also allowed me to sync/clear security issue. Only problem now is the car will still not start. No codes now after PCM replaced.
Old Aug 20, 2025 | 09:54 PM
davidh0765's Avatar
I did the testing you suggested on the schematic. Relay is not clicking when trying to start. No power to the starter (S) when trying to start. Starter did try to start when I jumped terminals 30 & 87 in the crank relay terminals. I should be getting 12volt power to terminal 86 in the crank relay when trying to start, but I am getting nothing. I also checked the 10amp ABS/PCM fuse in the fuse panel and it is good. Car has new PCM programmed to VIN and complete new ignition switch/cylinder. Any thoughts?
Old Aug 20, 2025 | 10:05 PM
02MonteSS_D.E.'s Avatar
Alright thanks for checking all that. Agreed the PCM is not supplying the ground to the relay to engage the relay. I see there is a 10 Amp PCM Crank fuse that is between the ignition switch and PCM input to tell it to start. Can you check that fuse as well? If fuse is good check to make sure the fuse reads 12 volts on each side in reference to ground when they key is turned to the start position. I want to make sure it’s not an issue with the switch suppling a 12v input to the PCM during cranking
Old Aug 20, 2025 | 10:13 PM
Sorry I reread that again. So you are not getting any 12v to the one side of the relay coil but the fuse for ABS/PCM is fine?
Old Aug 21, 2025 | 07:41 AM
If you don't have power to the control of the relay here is a wiring diagram of how the power is supplied to the relay coil.
Old Aug 26, 2025 | 08:41 PM
davidh0765's Avatar
I am not getting 12v on the ABS/PCM Fuse, but it has a new ignition switch, cylinder, etc. I also did the security reset process (30 minute process), and no security on dash now. Still not cranking and not getting 12v at the ABS/PCM fuse.
Old Aug 26, 2025 | 08:53 PM
Did you check for power at the Stop, Turn Signal and SRS fuses? These get the same supplied voltage as the ABS/PCM fuse does. If you have power there then I would start checking plugs inline to the next component and checking for continuity in the wires leading from the fuse to the crank relay. The wire colors are on that wiring print as well. Unfortunately your just gonna have to see where you have power and where you loose it and check in between. If you don’t have it at the other fuses check the voltage output of the ignition switch before it goes to the fuse. If you have it at the ignition switch but not at the fuse then check the wire in between and there is a couple connectors as well between them. The wiring print will help you a lot to trace down the wires. I hope this helps.
Old Aug 27, 2025 | 09:12 PM
davidh0765's Avatar
Thanks for your help so far. I was able to get back on things this afternoon and have re-tested a lot tonight. I don't know what has changed, and I am still having the No Start issue, but I am now getting power to the abs/pcm fuse when key is in the "ON" position as well as the "Crank/Start" position. Testing at the crank relay "Terminals", I am now getting constant power (Full time 12.53volts to terminal for pin 30, and 12.53volts to pin terminal 86 when key is in the "ON" position as well as in the "Crank" position. If I put multimeter probes (Ground to pin terminal 85 and power lead to pin terminal 86 when key is in "ON" position), I am showing 12.53volts. With these two terminals testing good for ground and power, that should activate the relay when key is turned to "ON" position and I should hear/feel the relay click. That does not happen. If I test the relay with jumpers from battery to relay terminals (Ground to pin 85 and Power to pin 86) the relay clicks and I have continuity between pins 30/87, which is correct and tells me the relay is working properly. I even put a new relay in, and still nothing when installed even though the terminals in the box are testing correctly. Why would the relay not activate when key is turned to "ON" or "Start" when Pin terminal 86 is getting 12.53 volts and Pin terminal 85 is grounded? Since the relay isn't clicking/activating, then it is not connecting pins 30/87, so no power is getting to starter signal wire terminal. When I use jumper between terminals for crank relay pin terminals 30 & 87, the starter activates. This has got me completely perplexed!
Old Aug 27, 2025 | 10:32 PM
Yes that is odd now your reading voltage, Not sure why you are reading voltage across the relay and it not turning on. Just as you stated you will have batt + power to the relay coil on the one side during ON and Crank. However the PCM grounds the other side when it receives a start command from the key switch crank input. Did you check the 10 amp PCM crank fuse I mentioned earlier? If that fuse is blown it will not receive the start input to the PCM and the PCM will not output a ground to the relay to turn on the crank relay. If the fuse is good, then check voltage at the fuse on either side in reference to ground and have someone turn the key and see if you get + batt voltage. It sounds like your on the west coast, wish you were closer I would come help you, I have a GM Tech II scan tool and I can see the power messages during different key rotations to see if the PCM is seeing a start command.
Old Aug 28, 2025 | 06:46 PM
davidh0765's Avatar
I am actually in Western Kentucky. I just discovered some additional problems also. Brake lights not working when brake is depressed. Turn ignition to on, and turn signal indicators on dash flash really quick and front turn signals on car flash really quick, but rear turn signal lights do nothing. Could I also have a failed BCM? Could a failed BCM be causing all of these problems? Do I need to find a Tech2 to diagnose these issues? Would I be able to tell if the BCM is bad with a Tech2 scanner?
