Info: No sound on radio in 2000 Monte Carlo
Old Aug 23, 2015 | 12:42 AM
2000carlo's Avatar
Default No sound on radio in 2000 Monte Carlo
I have a 2000 Monte Carlo ss. My radio has no sound although it clearly works, as it's still turns on and displays info. I've gathered (mostly from this forum) that my best and cheapest option would be to buy a metra amp bypasser. So I went inside my trunk and unplugged the wires connected to the amp and took a couple pictures. What I need to know is if the amp bypasser will work with the setup I have. Any help is appreciated. Thanks!
File Type: jpg
File Type: jpg
File Type: jpg
Old Mar 15, 2016 | 03:15 AM
bigcoop_03ls's Avatar
Bad amp turn on wire. The wire rusts on the passenger side,rear. The amp wire splits there and that's where it rusts. Splice in,or run new wires.
Old Jul 11, 2016 | 08:24 AM
TugBoat's Avatar
Default 01' SS Raidio no Sound.....Can't Sing!
I've read about all the answers and You Tube vids on this issue. Radio works, Amp "has Power" ( Mine only has 1 Orange and Black wire not 2 of each), Wires in loom under carpet "has Power". New speakers. Comes on & off..... All wires & connectors are good...Radio , loom , amp....
Heres a New ?????, My ignition is real sloppy to the point I can take the key out at any position. If its not completly turned off I can start it with a spoon.... Could the Ignition switch be the problem? On my Truck (GMC) that switch controls everything..... so wondering IF it could be that, Do I need the Switch and lock cylinder? My Wife is killing me over this NO MUSIC.......
Another ?, I've been getting recal notices and was told they Only give you new keys with a small hole to stop the swinging / bouncing motion. Do they give a New Ignition assembly?
Thanks!
MJClemm
Nov 11, 2015 10:50 PM
Xavier Willis
Aug 25, 2013 09:15 AM
gsteve
Feb 12, 2012 03:34 AM
Mr. 960
Mar 1, 2007 12:11 AM
