Bizarre AC issue
Old Sep 11, 2016 | 02:31 AM
Captn_Cook's Avatar
Default Bizarre AC issue
Hello, i'm having troubles getting my blower motor going. I've hooked it directly to the battery and it activates so the motor is good. There is no power at the red and black wire that go from under the dash to the harness. I've hooked the battery directly up to the harness so it was for sure getting power. Turned the car on and messed with ac settings and nothing. The plug that goes into the blower motor is melted...could that be it? Also, what is the purpose of the grey wire that comes from the dash and hooks up to the harness? Remote wire?
2004 3.8l
Old Sep 11, 2016 | 08:21 AM
The melted plug going into the blower motor could quite possibly be what is causing your problems. Question is...what caused it to melt??
I am not sure what the grey wire is for.
Hopefully someone who knows more about wiring will post.
Old Sep 12, 2016 | 08:36 PM
plumbob's Avatar
My guess would be the blower motor relay or resistor. You're gonna' wanna' replace that plug and test the relay and resistor. Replace as necessary.
Here's a schematic and illustration that might help.
Part:http://www.ebay.com/itm/Heater-A-C-B...5XLEAX&vxp=mtr
Video:
File Type: jpg
File Type: jpg
Old Sep 13, 2016 | 01:12 PM
Captn_Cook's Avatar
no relay on the 04 monte resistor is good and the plug is good. Tested plug by plugging the harness into the blower motor and not plugging it into the resistor and "jumping" supplying the collectors going to the blower motor with 12v. I'm probably just going to have to follow this power wire all the way through the dash till i find out where the power cuts out...fun times
Old Sep 16, 2016 | 07:32 AM
plumbob's Avatar
If you have, or know somebody with a Power Probe III it will trace the short to the exact point.
