NO POWER AT ALL 2000 LS
Old Feb 1, 2006 | 11:14 PM
skippermccoy's Avatar
Default NO POWER AT ALL 2000 LS
hello all,
i see that we all have alot of problems in common.i have the clunking trans which actually ended up over heating my torque convertor so i rebuilt the trans.it lasted about 20,000 miles then the intake manifold gasket went fixed that now the tranny is acting up again when you take off from a stop and hit the gas it slams into gear and then takes a long time to get fully ingaged into the other gears.the blinkers cut in and out,and the window goes down but you need to find that specail spot on the switch to make it go up.
the problem i am having now is there is no power at all no interior lights,radio or anything.when i turn the key to start it the check engine light lites up and thats it wont turn over and cant run anything at all.battery is brand new and shows full voltage.checked all the fuses inside and outside the car double checked all the harness plugs at the tranny and by the battery itself.where do i look now thanks for any help skipper
Old May 5, 2006 | 10:52 PM
speeddemon01's Avatar
Default RE: NO POWER AT ALL 2000 LS
there are fusible links under the hood also it could be a bad ignition switch
Old May 5, 2006 | 10:53 PM
ultrarevvin1
Vendor for sale section
Jan 11, 2014 11:56 PM
tbmaniacal
Nov 29, 2010 02:09 AM
Cyst3m
Sep 17, 2010 04:08 AM
jibb3r
Aug 3, 2009 05:22 PM
