6th Gen ('00-'05): No heat
Old Sep 29, 2017 | 02:52 AM
Shaunholton's Avatar
Default No heat
I have an 02 ss went to go to work and I have no heat? Was working before.
Old Sep 29, 2017 | 04:02 PM
SuperchargedMonte's Avatar
Check for any water/antifreeze in the passenger floor. If so, heater core went out. If not maybe the blender door is stuck that changes from air to heat. Does the air blow cold?
Old Sep 29, 2017 | 11:45 PM
Shaunholton77's Avatar
Yes it blows cold, this is the op couldn’t get into my other account for some reason.
Old Sep 30, 2017 | 12:35 AM
And if doesn’t look like any water/antifreeze is on the floor.
Old Oct 1, 2017 | 04:37 PM
Do you smell any antifreeze under the hood?
Old Oct 5, 2017 | 12:05 AM
Yes I have noticed it smelling like that
Old Oct 5, 2017 | 12:09 AM
Also checked coolant and didn’t have any in it.
Old Oct 5, 2017 | 05:12 AM
Refilled coolant and a few days later no coolant again.
Old Oct 6, 2017 | 05:01 PM
DAVESS2002's Avatar
Definitely a coolant leak, you need to get it pressure tested, put a pressure tester on the radiator fill tube and pump it up, then see if you can figure out where the leak is. Could be any hose or the radiator or coolant elbows that go from pulley tensioner to the manifold. Best case its a hose worst case could be a head gasket.
