New deck
Old Aug 13, 2006 | 01:04 PM
2000_BLACK_SS's Avatar
Default New deck
I have just recently put in a new deck and then had the great time of having a nail go in to my tire and the low tire pressure light came on and after i got the tire fixed the light is still on and the only way that i have heard to turn off the light is to use the stock radio. I will try anything so any suggestions would be nice.
Old Aug 15, 2006 | 05:57 PM
mickey's Avatar
Default RE: New deck
read your manual on this one i belive there is one that if you hang your head out the window at 55 and scream it will go off but not sure read the manual on the car i know there is another way to do it
Old Aug 15, 2006 | 10:11 PM
Greeny's Avatar
I heard that the screaming fix only works if you are speeding down the autobahn in your Monte Carlo.
Old Aug 16, 2006 | 01:30 AM
Bigg J's Avatar
LOL!!!!!!!!!!! that's a good one!
See, I was afraid of that whenI was considering an aftermarket head unit, since all I have is a cassette player. So I opted to have a CD changer installed to the factory radio. That way, I can still reset my oil life monitor and what not.
Old Aug 16, 2006 | 03:08 AM
02montels's Avatar
With the car on and running make sure ALL the tires are set at 30 psi, some people like a lil more or less air for the right feel of the car, most important make sure the pressure is equal in all the tires. Then with it running pull your headlight switch out to the FIRST click then push it back in. Do this 3 times and the light will go out and reset the system for next time its needed. Usually youll hear a chime when its reset but since thats contorlled through the factory radio and thats not in it now you wont hear it. Just make sure the low pressure light goes out after doing that 3 times with the switch.
Old Aug 16, 2006 | 07:20 AM
mickey's Avatar
i knew it worked for something. must be lean out the pax side and screm for the iss switch for the passenger then im not sure but some of the ideas of how to change the sensors are getting nuts. what ever happen to a small button for reseting things. Go figure that would make sens
CashMoney
May 31, 2011 07:16 PM
GreenEyedMonte
23
May 7, 2010 02:30 PM
Snolan860
May 5, 2010 11:14 PM
paintballerr78
Nov 26, 2009 11:17 AM
jkeller783
May 1, 2008 11:06 PM
