6th Gen ('00-'05): Negative cable replacement
Old Feb 4, 2021 | 07:31 PM
USPatriot1963's Avatar
Default Negative cable replacement
My 2000 monte ss needs a new negative battery cable. The new cable I bought has two wires with lugs and a small wire with a red crimpable open end. The old cable runs between the front of the engine and the radiator. I need to know where the cable ends terminate. When i looked at where the transmission is secured to the engine, I saw a black cable secured to the housing by a large nut. Is this the terminating end of the negtive battery cable? Any suggestions?
Old Feb 8, 2021 | 09:16 PM
GrayGhost1951's Avatar
I thought mine needed one and it turned out all I needed was the battery bolt which was almost gone. Threads were rolled over and it would not tighten up.
TexasGunner
Aug 25, 2016 03:58 PM
Red Nightmare
Apr 4, 2013 10:34 PM
LTs_Carlo_SS
Apr 20, 2011 03:43 PM
MY 06 LT
18
Apr 2, 2011 02:08 PM
Visceron
Dec 3, 2010 07:34 AM
