4th Gen ('81-'88): Need window help
Old Jun 5, 2016 | 02:16 PM
Torn151's Avatar
Default Need window help
i have an 84 monte ...driver window would not roll down So i replaced harness. switch & motor and window works..( checked both windows and they both worked )....put the door panel back on and now passenger window wont work...Any ideas ??
Old Jun 5, 2016 | 02:57 PM
Sounds like something came loose when you put the door panel back on if they were both working when it was off.
Old Jun 8, 2016 | 08:35 PM
jakefluker's Avatar
Yeah double check connections
