Need window help
i have an 84 monte ...driver window would not roll down So i replaced harness. switch & motor and window works..( checked both windows and they both worked )....put the door panel back on and now passenger window wont work...Any ideas ??
Sounds like something came loose when you put the door panel back on if they were both working when it was off.
Yeah double check connections
